I would be grateful for any advice on a CH problem which appears to be getting worse.
First things first..system is Potterton Kingfisher 2, RS 60 boiler, gravity water fed , pumped CH. Primatic cylinder. Radiators: 3 largeish, 4 small, grundfoss 3 speed pump.
The radiators no longer seem to get that hot and the system now takes about 1hr 15min to reach operating temperature. System seems well balanced but heat is not really there.
Have looked at boiler heating up and have observed that the flame is roughly on for 2 mins and then off for 1 min even from cold. Should the flame be lit continously while it is warming up? (The boiler stat and room stat are set to max). I have also noticed that whilst the flow pipe gets very hot the return pipe gets only luke warm even after 1 hour. Flame burns blue and looks good. The pump sounds as if it is working ok and you can hear a change when the speed selector is altered, albeit faint, (I have it set on 3). I have removed each of the radiators and reverse flushed them in the garden. Some black sludge came out but system now clear. I assume I cant use system corrosion inhibitor because of the primatic tank so will have to flush every other year.
Can anyone suggest how I can get the radiators to feel like a little more than cupboard heaters!!!
Many thanks
This problem seems to be 'creeping up on me' I am sure it is worse now that it has ever been. Two of the radiators were added by me last year to complete the system. After some difficulty balancing them all I remembered the system as working ok if a little slow.
Many thanks
