Hi there,
I need some help and advice. I took off the two double radiators in the living room in the summer as we decorated the whole room, plus the one in our bedroom as well. I have started the heating up and initially everything was fine as all the radiators seemed to heat up. However, what has happened now is that the radiators downstairs don't come on if the hot water is on but the ones upstairs do, they are nice and hot.
The only time the radiators downstairs come on is when I turn the hot water off, and only one of the pipes going to the radiator is hot, the other end is cold.
When the radiators downstairs do come on they heat up from the top and they take a little while to get hot.
I have bled all the radiators and there is no air in the system at all, I have even tried to bleed the whole system but again there seems to be no air in the system.
I have spoken to my Dad and he seems to think that there may be something wrong with the Tri-Valve next to the pump in the airing cupboard. What do you think?
Also, I have three tanks in the loft, does anyone have any idea what the third tank is for?
Any help and advice would be gratefully appreciated.
