Central Heating RADs not Heating - New System
Hi, I have had a new Boiler Vaillant EcoTect Plus 831 and 8 new radiators installed as part off my building work. Now the system wasn't tested as the building work went on but was getting hot water coming out.
Now the hot water works perfectly and heats up efficiently.
The problems lies in the RADs. The pressure is at 2.4bar and all rads are bleeded to let all air out.
The first 2 closest radiators heat up boiling hot but the water water hardly reaches upstairs. You either get cold or warm pipes and rads never heat up.
I researched on balancing and closing the first 2 boiling rads supply to quater turn and left for 2 hours and still nothing.
Now I shut all rads and only left one open in the bedroom and still hardly ever get the hot water to travel upstairs.
The return pipe is always cold. Now I'm not sure if the setting on the boiler are set correctly or needs tweaking. Read the manual few times and i found my way round the menu system.
Any advice?
Any advice?
