Hi all
Yesterday I had most of my radiators refitted after removing them a around a year ago to replaster & redecorate. This is the first time all the radiators in the house have been connected & its a full central heating system since I had a new combi boiler installed around a year ago. I bled the radiators (bottom to top) & topped up the boiler so the pressure is correct.
2 rads which were removed for a year are not heating up at all,
Another rad which was working until a couple of days ago when it was removed to paint it is not not heating up at all.
On all rads both valves are fully opened to the max.
Any ideas what else I could try myself instead of calling in a plumber? I've been reading up on the net that I may need to temperature balance each radiator using radiator thermometers on the inlet & outlet pipes until the temp difference between the two is 20 degrees.
Also another 2 rads I could not bleed because the bleed screw was too small & neither of my bleed keys could grip it. Is there more than 2 sizes of bleed key? These 2 rads are also not heating up.
Thanks in advance.
Thanks in advance.
