I took two radiators off for decorating, I have put one back and filled due to cold weather. Yet to put the other one back on. I have decided it would be good to add inhibitor due to having diluted the system, and by replacing the second radiator I will be diluting it even more.
Only thing is I can't be sure what inhibitor was previously used. When the boiler was installed in 2004 (long before I owned the house) Sentinel was used according to the warranty document for boiler. Although the previous owners had a loft conversion in 2006 and two radiators were added, so the system may have been drained and refilled then, and possibly a different (or maybe even no) inhibitor used!
I was going to use Sentinel Concentrate, and my questions are:
What are the consequences of mixing two different makes of inhibitor? I know it is not advised, but what are the side effects?
What is the best way of getting it into the empty radiator, which is currently off the wall and empty. Can I inject it into one of the bottom inlets and is the concentrate gel thick enough not to run out when I reconnect it?
It is a sealed system with combi boiler.
Regards
Regards
