All of the water in my radiator system was drained in March as I needed a new radiator fitting. Due to the nice weather back in that month, I only turned the heating system on 3-4 times more, yet one radiator needing bleeding as a lot of air had got (although I think that after a drain out, one should expect to have to bleed a radiator - is this correct??). Due to the colder weather now the time has come to turn on the central heating system again. If the radiator keeps filling up with air what would happen I was away for a while and unable to bleed it .... would the air eventually fill all of the radiators on the system or just block out the defective radiator and leave the other ones alone?
