radiators
3 Oct 2008
Norfolk
chemical flushed under pressure in heating system. Since then some upstairs radiators need bleeding every three days. This problem has been continous since november 2008.
The only fitting done was a gate valve on f&e tank
Have you checked whether the ball valve in the f&e tank is constantly running/dribbling?
If so you could now have a leak caused by the flushing and fresh water is constantly entering the system and giving of air when heated.
Te gate valve on the & e tank: was it on the cold feed pipe (which is not allowed anyway)? if so - are the compression nuts tightly done up - small micro leaks which allow no water out but air in, can have a build up which causes air build up regularly in the system.
possibly not flushed and neutralised properly depending on chemicals used and still reacting with system
