Hello,
I have a Glow-Warm Back Boiler behind gas fire in chimney breast downstairs. There is a feeder tank in the loft and the hot water is warmed via the coil in the immersion tank. No automatic valves exist. I assume this is what is known as gravity fed.
2 Problems:
1. Had to drain the system to move a rad in one of the upstairs bedrooms, however, after refilling i bled the rads and the rad that was moved only got warm at the top, it used to get hot like all the others before i moved it (i should point out that i fitted a TRV to this rad as it is in a childs room, i have checked the pin and it appears to be free i.e not sticking). After a while it was completely cold, all other rads are hot. Shut off valve is open (or a least i have turned it open all the way, so it should be open as this is also a new valve). I have checked again for airlocks but all would appear to be ok. Booklet for TRV said to fit it on the flow side (picture showed this as the right hand end of the rad so that the arrow could be seen on the valve), i assume this is correct, how do you know which is the flow side?. This rad is at the end of the circuit as far as i can ascertain, it does no appear to tap off.
2. Since refilling i have no hot water (i do if i heat it via the element). The pipe into the top part of the coil is hot, but the one leaving the coil at the bottom is cold. Is this an airlock or a blockage? How do i go about clearing it?
Any help would be much appreciated!!
Many thanks
2 Problems:
Many thanks
