Hi all. Just to confirm that the previous thread(coil pack related) which turned out to be a spark plug has been completely resolved. Engine light turned off and car driving well.
Car test tomorrow, so hopefully good news!!
A strange thing has started happening now though. My radio comes on, after I've turned off the engine and removed the key. Air con and radio actually. I have to remove the fuse to stop it from happening. This is a MK II Seat Cordoba with the LCD display screen.
Not sure if it's a car test issue though, but annoying.
Also, and finally, My key fob takes a long time to open the central locking. When I press the fob, the diode on the key lights up but it sometimes takes 30 to 60 seconds of pressing before the car opens, and since the key doesn't manually open the car(locks must've been changed by former owner), I'm worried about changing the battery in the fob. Because the fob then needs to be reset, and I've heard all sorts of stories about them not working properly. But also, since the diode in the fob works when I press it, I wondered would changing the battery even be the issue!?
Any tips? Thanks.
Any tips? Thanks.
