Rads advice
4 Jan 2006
Derby
Having four new radiators fitted on downstairs extension and utility room. The flow and return connections are easily accessible. All rads and valves are supplied what would be the cost to have this work done. The boiler is a Worcester Bosch combi. Do the pipes that feed the up pipes for the rad need to be in 22mm or 15mm. Thanks for any help
Best to feed each rad in 15 mm (if you can) by teeing off the 22 mm F & R.
As for cost, hang the rads yourself approx 2-3 inches above skirting will bring the price down a bit. I would expect to pay £150 plus for labour. :D
