Rads / Boiler
22 Dec 2003
Boiler downstairs runs for two mins goes out continually
Rads downstairs cold
All upstairs heating is fine
Hot water in the house is fine
What sort of system have you got?
What sort of boiler is it?
Do you have a hot water tank?
How big is it?
How big is your cold water tank?
What else can you tell us?
Hi Oilman,
I have exactly the same problem, upstairs rads hot, downstairs cold.
- I have a Gas fired heating system(Mains)
- Potterton Boiler
- yes, I have a hot water tank in the loft
- 20 Gallon
- Cold water tank is also 20 gallon
-- the water pressure is at 1.75bar, I have hot water.
when the system is on, it fires for 3-4 minutes shuts off for same and fires again.
With the time of year that in it I would appreciate any help or advise as I can't get a Plumber to come and look at it until after Christams.
Hi chrishildreth, as you can see from my earlier mail, I had a very similar problem as you are describing.
Replacing the hydraulic valve in my boiler (Done by a pro) seems to have solved the problem.
Not sure if this will help you, but thought I'd let you know anyway.
Sean.
