I am having a problem with my gas heating system - all the radiators in the house and the pipes supplying them are cold but there is hot water in the cylinder. Does this mean there is a problem with the pump?
I thought someone might have some things that I could check before I call in a pro....How come the boiler is heating the water in the cylinder but not the rads? Just don't want to shell out for something that might be fixable by my humble self.......
my CH/HW system at home has a small level next to the boiler which diverts water between the HW and the CH. during the summer we moved it all the way over to the HW side and this stopped the heating. great.. . until it stuck and had to get it replaced in october!
check to see if you have one of them!
Understand that, but your not telling us anything about your system. Is it gravity fed hot water, pumped central heating ? Is CH selected ON, on your programmer ? do you have a room thermostat ? is it turned up ? If you switch the hot water off and turn your room thermostat up does the boiler fire, etc, etc.
