Ravenheat LS 100T boiler. Replaced the diverter valve diaphragm at the weekend and solved the problem of dhw taking several attempts to fire up. The problem now is that the rads heat up whenever the dhw is turned on. It used to do this before. Seems like the valve still has a problem???? Cleaned the valve out whilst removed and black stuff I think from the old diaphragm came out. The div valve is the 000VAL09010/0 version and uses the same diaphragm as Aplha CB24. Any advice appreciated.
