M
marsaday
I will be putting a rad (10,000 BTU) in the bedroom of my attic conversion and a towel rail (1200 btu) in the bathroom. Will this be enough or should i put one in the landing area.
Basically our house is a square box and the front right hand corner is given away to make the stairs, so it is quite a bigish area. Because of this i thought it may be a good idea to heat this space properly.
We already have a rad in the hall and a rad on the half landing.
The reason why i am thinking i should heat the hall area at the new top of the house is so the central heating will not stay on for ages getting up to heat. Eventually the heat will rise and hit the roof (which is now well insulated) but the time it takes will be reduced if i heat this up from the top.
What do others think ?
Do you need any dimensions ?
