Hi all, ABout two years ago I installed with my plumber friend a HEP (22mm) based system with a system boiler and megaflow. The heating recently about 2 years after installation I think is different. The rads downstairs which all have 3m drops down from the ceiling to the rad in 15mm copper seem extra cold at the bottom. When the heating is on the rads are superhot at the top where you cant really hold it but I can hold the locksheild pipe going back up to the ceiling and the bottom 50% of the rad is quite cool and easy to touch. The rads are all K2. I dont believe it was like this before any advice what it might be?all downstairs rads all are K2 and 1200mm wide minimum. The baxi system boiler is reading nearer 2bar pressure, When i have decorated each room i have removed the rad. As eacg down stairs rad is fed from the ceiling down they all have 3m long drops (tall ceilings) and is all in 15mm copper from the ceiling down and 22mm from the boiler. I have experienced air lock in the down pipes when reconnecting the rad. to help resolve this I switched all TRV's off and put the one rad on full blast and it heats up evenly. Could the return pipe be airlocked?.... Any advice? should I drain down and refill I have alwasy topped up the inhibitor?
