We have a combi boiler and all but two of our radiators have thermostats fitted. The rads with stats only heat up fully when the stat is on its highest setting - Any ideas?
What is the temperature of the air? If this is hot enough, the stat won't open. What position is the stat in? if it's on the flow end of the rad it may see the heat generated from the pipe.
