hi guys
got a 4 year old persimmons new build with a baxi 50ff and megaflo cylinder piped on a s plan. custard foned me saying that 3 rads were getting hot but now are not. standard pipework to the rads ie plastic 10mm behind dry lining to a patress behind rads then elbows across to valves. now one of the rads has had a rad in the conservatory added to its drop, so one pair of 10mms serving 2 biggish doubles, so im not empecting them both to get red hot obviusly, but the other 1 is on its own drop from above. custard said its had a 15/60 pump change before i arrived on the scene. ive taken all 3 rads off and flushed them thru with hosepipe, run 2 litres of x800 in system for 3 days not much gunge in em at all. i,ve taken the pushfit valves off, all clear as a bell. i,ve put some compressed air up the f&r,s all seems clear. reinstated system everything gets hot for a couple of days, then all 3 drop off to luke warm at best! do u think there is a blockage where the 10 mm,s tee off on the carcass- or is there anything ive missed. if youre still awake id appreciate your thoughts!
