Rads upstairs work ok, downstairs they dont, hot water is OK
26 Sep 2004
Please can you help, the whole central heating system was working OK. Now the upstairs works OK, but downstairs none of the rads are getting hot (or even slightly warm). I have checked the pump which is working, the two diverter valves are working. I have tried setting the diverter valves in postion A, B or mid position and in several combinations. Any suggestions as to what the problem may be?
Thanks Martin
are you sure the pump is working and is it working to full capacity?
THE PUMP IS WORKING 100%. IF I CHANGE THE FLOW RATE I CAN HEAR IT ALTER THE THROUGHPUT.
