rads
2 Aug 2004
On a combi system with trv,s fitted to all rads does the other valve have to be fully opened or do the rads have to be balanced as in a conventional system.
As conventional.
Or you can be unconventional. If you look under the top of many a trv head such as a Drayton or Honeywell, you'll see a plastic ring with a slot, around the central pin. Turning that limits how far the valve will open. In effect a balancing adjustment. It's in the instructions which nobody reads!
