When working out the depth of a floor joist in relation to the span I use the span times two + 1 inch as a ready reckoner, however, at this point in my life, I am pitching a small lean to roof. This part of the project isn't under building control nor are there any architects drawings nor eng calcs, therefore I pondering what size timbers I should use for rafters for the length I am covering. The pitch is 22.5 degrees and the length of the rafter on the underside is 2.6mtrs, maybe 2.9 overall. So if Iwere to use the joist theory then 7x2 should surfice
But to be fair, I don't think the same rule can apply, as i imagine the pitch of the roof and snow loads also play a part, could someone offer some guidance please,
