Wondering the best way to insulate a pitched ventilated roof at rafter level to the standard required by document 1Lb (Oct 2010). The recent change to the building regs require U=0.18 on pitched part of roof of attic rooms or loft conversions rather than the previous 0.20.
Noting the varied recommendations made in previous threads (for the original standards), and the variety of configurations accepted by different BCOs (which don't seem to match the older standards either) the whole thing seems rather a black art! I have doubts if the differences between 0.18 and 0.20 are noticeable in terms of fuel bills or comfort, especially given the house walls of solid brick are U = 2, but let's say we really want to achieve 0.18 not just get a tick from the BCO.
I have found some solutions in product literature that are BAA certified and LABC registered (and that should be good, right?) that achieve 0.18 for a non-breathable felted roof (vented from eaves) with nominal 100x50 rafters at 400 spacing.
Kingspan - rigid foam boards -
1) 50mm gap, 125mm K7 (phenolic) between rafters and 38mm K18 overlay. [213mm total thickness]
2) 50mm gap, 140mm TP10 (PIR) between rafters and 38mm K18 overlay. [228mm total thickness]
Web Dynamics - multifoil augmented with other -
3) 50mm gap, 90mm Phenolic (e.g. K7), 20mm gap, TLX Silver across rafters, 38mm baton, plaster board. [225.5mm total thickness]
4) 50mm gap, 100mm PIR, 20mm gap, TLX Silver across rafters, 38mm baton, plaster board. [235.5mm total thickness]
5) 50mm gap, 140mm mineral wool, small (?) gap, TLX Silver across rafters, 65mm baton, plaster board. [302.5mm total thickness]
6) TLX RafterFit between rafters (gaps above and below), 80mm phenolic across rafters, plasterboard directly on top. [192.5mm total thickness]
7) TLX RafterFit, 65mm PIR across rafters, spacer baton, silver backed plasterboard. [202.5mm total thickness]
All solutions, except for those with RafterFit, require extra timber to deepen each rafter by at least 60mm (up to 90mm for wool). This, the minimum thickness (thus loss of room space), and ease of fitting between wibbly/wobbly rafter timbers, makes the RafterFit route look attractive. But not sure about the long nails needed for 6) through both plaster and phenolic boards, could be tricky to handle. Anyone actually done it?
Then, of course, there is Actis Super 10. A couple of loft contractors have quoted to use this, and were certain it alone would pass BC even when I pointed out the changes in building regs. There seems to been a whole load of controversy about using multifoil products (alone), has that been resolved yet? Are Actis going to change their blurb to say "0.18" rather than 0.20? Will BC accept it now there are certified combined solutions, which if they are accurate imply super 10 alone can't be.
Will it take a while before BCOs are insisting on 0.18 compliance, or will they enforce the new value immediately?
As you can see I have done my homework, although I am sure there are other products out there too, but just not sure what path to take. Good practical advice, pros and cons much appreciated.
