Hi, I want to insulate my garage roof rafters and the timbers attached at at 45degrees in the picture will make the job a pain but I was wondering if they are actually structurally required, or were they just used in the construction of the roof and just left attached?
I'm sure that was their function when the roof was being constructed, but now it's build an tied into the wall etc are they still required? I don't recall seeing these on other houses I've lived in.
They are required, though it looks like someone has gone a little mad with the diagonal wind bracing and I would have expected to see a longitudinal piece at the node point on the ceiling.
