My parents have had a problem with their garage for the last 5years where it literally rains in the hot weather. The garage is a link type between two detached houses and has a bitumen flat roof in place. The roof appears intact and the join onto the house appears sound with good flashing.
The garage was converted by the previous owners into 'a habitable room'! Now my parents are elderly and have the heating on full tilt all year round and its my guess that the condensation in their garage is due to a poorly ventilated flat roof space.... They have had several tradesmen out to assess the situation who are apparently 'baffled'.
The condensation only occurs in the hot weather and stops in the Winter. One tradesman reckoned that there was water ingress from the main house into the cavity wall where it then ran along the brick ties and worked its way into the roof space rafters to cause this problem. Personally I think this is a crock.
I have told them to get someone to rip the plasterboard roof panels off and take a good look but they say that the tradesmen have looked through small holes so far and don't think its needed.
Another guy has been this week and has found that theres a load of tightly packed rockwool which is soaking wet in the area that he looked at. He reckons that there is too much insulation up there which is tightly packed.
I have yet to go there to look at whats been going on but it sounds like this last guy has found the problem ie the rockwool and my theory of no ventilation is likely to be correct. Does this sound reasonable?
Do flatroofs usually have a ventilation system like soffit vents? Obviously the roof was designed for a garage and I suspect that the previous owners have cut corners and bodged the job up.
If I am right then I plan to rip the boards off and remove the rockwool. I will then put some vents in the soffits or fascia boards (if there are any!) above the level of some new kingspan polystyrene insulation and reboard/plaster. Does this sound reasonable?
