I’ve just had a dwarf wall for a conservatory built and have noticed that there is rainwater in the cavity about 50mm deep after heavy rain earlier this week. The rainwater appears to be seeping in from the outside as when I empty the cavity wall it fills up slowly and I notice the water level around outside wall goes down. The water is still well below DPC level and I think it is coming in where the wall meets the foundation maybe through the pointing done at the foundation when the first brick course was laid.
Is this normal? Is it expected if there is water sitting outside the wall due to heavy rain that some is expected to seep in and eventually will subside as the outside dries? The soil is clay hence the water logging issue on the outside.
