Have been to quote someone for full replacement soffits, fascias and gutters. There is a downpipe front and back and a long 10 metre run on the side. There is no downpipe or drain on the side.
Now this chap says there is a plastic soil pipe along the side which goes up from the concrete ground, up the wall and then swans out and up right next to the guttering. He wants me to put an outlet above the soil pipe, cut a hole in the soil pipe and lead the water into it via a small bit of cut tube.
Now I always thought you should'nt mix rainwater into waste but this guy says he owns a building company and knows all about these things and says legislation etc has changed He says its fine and he knows what he is talking about
Now has almost convinced me that i'm wrong, not him
I have explained with the new square gutter we will be installing as long as we do the fall correctly, he will never have any problems with the side, even in heavy rain.
Could someone just reassure me i'm right about not putting rain into waste, but i'm happy to admit wrong if someone could put me right
