Raise floor under carpet
3 Aug 2005
Surrey Hills
I would like to raise my sitting room floor by 5-10mm before installing new underlay and carpet (to reduce the difference up to the hall).
The room is approx 4m x 5m, has floorboards with a 600mm cavity underneath; as there is no insulation and I thought I may be able to use something that may also reduce draughts and possibly add some insulation properties.
What are my option for raising the floor? Would a woodfibre underlay board be suitable?
Possibly one of these:
https://www.screwfix.com/p/wood-fibre-underlay-boards-7m-15-pack/7824R
https://www.screwfix.com/p/vitrex-premier-wood-laminate-underlay-boards-5mm-9-76m/68038?
Both Q&A's on the Screwfix site suggest they are unsuitable for carpet.
A thicker conventional rubber underlay might help with insulation
If it's difficult to raise the overall floor by that small amount, an alternative is to use a suitable carpet cover strip at the door opening.
Blup
8x4 sheets of hardboard would easily raise height and are ideal for under carpets , rough side up .
Prevents uneven floor boards showing through .
