Hi
We had some work done recently. This involved adding new electrical sockets & then the walls were subsequently skimmed. I bought (and had fitted) some modern sockets with a front that clips on and barely protrudes from the wall. It clips onto a facia that is screwed into the box that is sunken into the wall. unfortunatley, I (and the electrician) did not quite think things through. This facia must fit just proud of the wall. Since the wall was skimmed after it was fitted, it no longer sits proud of the wall.
I need to have the facia extend an additional 3 or 4 mm further out. I imagine I can do this by adding four <somethings> into the four corners of the sunken box that extend 3 or 4 mm that the facia can rest back against. I am considering some small pieces of wood and adhesive however I want to check if there are any specific no-nos I should consider. I was going to use gripfill but noticed it is highly flammable.
I appreciate this is a bit of a bodge but I am at a loss. If I dig out the box to raise it back to the new plaster face I will need to plaster\ fill around it again.
Any pointers?
Many thanks
Any pointers?
Many thanks
