Hi all,
Since I was unable to source matching paving slabs to finish a small area (left on the pic) due to some reworks and my missus prefer decking here I am for some advice.
I am planning to build decking to the same level as the kitchen/dining floor. The decking area will be slightly bigger than the existing patio 5.6m x 3.3~3.5m (5.6 x 2.8m).
Considering the slabs are solid with no movement I am thinking of living them intact, fix bolt down mounts with 4x4 posts, then bolt 6x2's onto them to build the frame with 400mm noggins.
My concern is about the DPC and air bricks as the decking will be over them. I plan to leave 10mm gap between the back board and the wall to allow for air circulation. I guess anchor masonry bolts are ok to fix the back board, but what size board and bolts should I use, are there any standards for this?
My other dilemma is which way to fix the decking boards, parallel to the house would be less slippery, 90 degrees to the house would look better and would allow better running off of the water, what are your thoughts?
Thanks in advance
Thanks in advance
