I have no contacts within the building trade and no-one I know can recommend a good builder in the area, (Dartford Kent). As the following job, done wrong, may bring 3 stories of chimney into my kitchen, any useful bits of advice or contacts would be much appreciated.
Our kitchen once had an aga in the brick chimney breast. When this was ripped out, in 1996, the gap was raised to accommodate an extractor in the chimney and a gas hob was installed. The builder (a local handyman) put in a cross section spanning the gap between the brick sides at the new height.
Current regs dictate that, if another hob is ever installed here, I will need to go up by another 2 brick heights. As I would like to put in a range, I hope to do this in the next few months.
Further, I understand that, as it is against current regs, no-one would be prepared to replace the hob if it ever died, is this true?
Thanks for any help
Thanks for any help
