Hiya!
I've a wetroom tray on it's way which will take up one end of a 4' x 12' room, it's about an inch deep so the rest of the room needs raised to meet it. No big deal as the next rooms floor is higher anyway as it was built with this in mind.
Now then the existing floor is concrete... it's as close to flat / level as i'd hope but not exact. What i'd like to do is buy an 8' x 4' sheet of some sort of wood and stick it down with adhesive so i can level it and get it spot on, also flush with the shower area. I should mention the whole area will be tanked later.
Is this do-able? And if what products would you recommend? If not, how would you tackle it?
Many thanks.
Many thanks.
