Hi all, looking at buying a new house and across the back there is an odd sized extension of about 3m x 0.7m and a bit which is a bit wider of about 1.8m x 2m. One part extends the dining room and the slightly wider part is an outbuilding on the back of our kitchen.
We're thinking about knocking through into it from the inside so its a lot more open plan and also fitting some french doors, however the ceiling/roof is quite low.
Can anyone advise how big of a job it would be to effectively raise the roof up by a about 50cm so that when it is knocked through the house maintains the same ceiling height (or as near as possible).
You may think this is an odd request but it would make the kitchen we have much more usable when we come to knock the walls down and would give us more usable wall space (at the moment the low roof means we wouldn't be able to put wall units up etc.)
Is this a massive job? Anyone any ideas how much its likely to cost? By my reckoning you wouldn't need any new slate for it as it can rebuilt at the same pitch just at a higher level. Just the outside walls will need to be built up to accommodate it. Theres probably lots more to it than that but just wondering if anyone can shed any light on it?
