- Joined
- 17 Sep 2018
- Messages
- 2
- Reaction score
- 0
- Country
Can anyone suggest a solution please??
I recently used a well known highstreet chain's own brand paint in a small bedroom which began to peel off when I removed the masking tape and resulted in me having to scrape it all off. I used a heat gun and it peeled away much in the same way as wall paper does. I then sanded down the most stubborn areas with an electric sander which took off some of the previous paint and exposed some of the plaster in some parts.
Local paint shop advised to paint the exposed plaster with watered down paint before re-painting with a better quality paint. Our house is 10 years old and that room hadn't been painted since we moved in and I had the original watered down paint stored in the attic so asked the shop owner if this would still be ok to use and he assured me it was.
I only used the watered down paint (the photo should give a better idea of size) on an area roughly 1m square and approx 20 - 30 dots varying in size, from a 5p piece to the size of a c/d. I then painted over with the better quality paint.
The problem is that there is a sour, damp, revolting smell in the room and I'm convinced it's from the now dried old watered down paint. This bedroom is meant for my two year old and I can't use it as I'm afraid the odur could be harmful. I'm really hoping there's a product someone can recommend to eliminate this odour and make this room safe and habitable again or even someone who has been in a similar situation and share with me how it was resolved.
I partially blame the paint shop owner for my predicament, but alarm bells should have rung when I opened up the paint and thought the smell was a bit "off" .... I should have known better at my age!
