My Randall 103 timer is turning too fast and you can visibly see it! Anybody have any ideas as to what is wrong please? If is is no good now can I replace it easily and cheaply? Do you have wiring tips please?
Its had it new one req like for like will take you 2 minutes .
Hole in bottom trim undo screw take trim off and push clock up and off pins .
Fit new one
The 103e is digital now.One screw to remove underneath and push the module upwards off the backplate.Plug new one in and replace screw and cover.Isolate electrics first.
