Range cooker
17 Jan 2007
Yorkshire
Just checking installation of a range cooker, I have a gas outlet behind the cooker, screwed to the wall, which means i cant push the cooker right back to the wall? is there any alternative connection that can be made to remove the wall plate? Its fitted between cabinets
Also, I the cooker needs to be raised about 35mm, Can this be done on the feet or would i be better putting a flag uner the whole thing?
Andy
Haven't seen your pipework, but I'm guessing the back plate elbow is on the wall and the bayonet is directly in front (hope you get what I'm describing), if this is the case and the problem of why you can't get the cooker back enough, you can get a 90deg elbow that would bring the bayonet closer to the wall
What about raising the cooker to a more suitable height? im thinking if i do it with the feet then i will have a big gap for food and dust to accumulate?
be surpised if it will raise 35mm on feet anyway. Probably need something underneath it. Check installation instructions for location of wall elbow, maybe its not in the right place.
