I have a Powermax 155x (open vented) which was installed in 2004 when the apartment was newly built. I’ve been getting hot water fine all year, but no heating to my radiators since trying to turn it on for the first time this winter. Here are my findings so far;
• CH pump seems to be running
• Bathroom towel radiators work fine
• No other radiators work in the flat
• Just on the radiator nearest to the boiler, after a while the (outlet?) pipe gets hot, while the other pipe connected to the TRV remains cold/lukewarm. All other pipes in all other radiators remain cold/lukewarm.
• Removing this particular radiator, water seems to run fine from both the outlet and inlet pipes.
• I have also bled all radiators – appears to be no air in the system.
Given these observations, what would you advise?
Thanks in advance
Thanks in advance
