Range tribune he
29 Jul 2024
Hi, just moved into a flat that has been empty for over a year, I turned the night supply for the hot water on for the first time after around 25 seconds the pressure drops off. Any ideas or advice of what the issue could be?
Hi, yes main tap is open enough, cold water runs fine
And yes sorry flown from the hot water tap, cold water runs fine but hot water drops off after 25 seconds or so
Expansion vessel.
PRV.
Or, bad install if you've just moved in you don't know if it always did this.
