rattling from the bypass radiator
1 Apr 2010
Mid Glamorgan
I have just removed a radiator and some pipe work which involved draining my heating system (combi boiler) Having done this many times without a problem, I was not that lucky this time.
there is a 400x400 radiator in the airing cupboard which is the bypass for the boiler but after filling this time there is a rattle in the radiator (sounds like a piece of metal rattling inside)
I removed the bypass radiator this morning to see if anything was loose but no luck -
ANY IDEAS?
When i removed the radiator and pipe work i terminated with isolating valves as i want to put a new radiator back in a different position -
SHOULD I MAKE THIS A LOOP I.E ATTACH A PIPE TO JOIN THEM?
Many thanks
John
You could try flushing out the radiator in the garden, or it could be the plastic lugs on thw wall brackets that have fallen off/degraded.
