Hi all,
The Low Pressure light on my Potterton Puma 80 combi boiler recently came on and the boiler stopped firing up for both HW and CH. I checked the pressure and sure enough it was around 0.5 bar. I topped it up to around 2 bar (where my red pointer is) using the filling loop, but the Low Pressure light stayed on and the boiler failed to fire. I topped it up till it was at 3 bar but still no joy.
After searching this forum for hints it sounded like the Pressure Switch may be stuck or broken. I disconnected this on the PCB, turned a hot tap on and hooray, the boiler fired up! However whilst reading around I realised I'd been foolish in letting the pressure get so high, so I bled the radiators till the pressure was 1.5 bar.
HW and CH are working, but the problem is that the boiler makes a loud rattling noise when the taps are turned OFF. While they're on it's making the "normal" amount of noise it always has. I turned the CH on for 30-45 mins and again it made a normal amount of noise, but after a while it started rattling, getting progressively more unsettling and louder until I turned it off. The radiators do get hot and there's hot water coming from the taps, so it's just the noise and the stuck/broken Pressure Switch that are worrying me.
Any help would be much appreciated!
Yours shivering,
Ciaran
EDIT: Just to add - the HW & CH were working fine until a couple of days ago, before the Low Pressure light came on.
I also turned off the mains water recently to fix a leak with the dishwasher. A few days before the Low Pressure light came on I had to loosen the mains stop cock as the cold water pressure was too low.
Yours shivering,
Ciaran
