I have cowled vents on both my bathroom and kitchen fans. They're both on the same side of the house and have been rattling really badly with the wind over the last week.
I was wondering whether it'd be worth replacing the cowled vent with a standard louvre (with or without flyscreen - particular in the kitchen fan this seems like it must just get clogged up with grease and make the fan less effective?) and fitting an inline back draught shutter instead. The bathroom fan has quite a lengthy vent in the loft so I could fit the shutter quite some way from the outside if that was likely to be beneficial.
Firstly, is an inline back draught shutter likely to remove the problem, or is this likely just to rattle instead?
Secondly, if I go with this approach, where exactly should it be mounted? In the case of the bathroom fan which is an in-line type, I assume it should go between the fan and the outside, but should it be as close to the fan as possible, as close to the outside as possible, or somewhere in the middle?
Thirdly, can anyone recommend a good quality back draught shutter? I've noticed some reviews criticise the springs as being inadequate and the flaps never closing entirely, though I guess there's a limit as to how strong it can be or the fan won't be capable of opening it?
Alternatively, any other suggestions for me?
