ravenheat 100et combi ignition problem
22 Nov 2007
Manchester
auto ignition is a really weak pilot,changed pilot injector,ignition board and ignition lead,sometimes goes to full flame,more often goes to lockout, anyone got any pointers??
Back to basics. Has the working pressure been checked at your gas meter?
Has the inlet filter on the gas pipe on the boiler been checked, assuming one is fitted?
hi dave,20mbar coming in checked meter governor also,even removed pilot tube and lit when going through sequence,not sure if there is a pilot adjustment screw on this gas valve cant see one??
