Ravenheat 802/20 Hot water problem
4 Jan 2010
Humberside
Suddenly the hot water output on my Ravenheat 820/20 has stopped. When drawing hot water the main burners do not ignite. However if I turn up the room thermostat so that it turns on the central heating the main burners ignite and I can get plenty of hot water. The radiators are cold for as long as I draw hot water but get hot as soon as I stop using hot water, so the central heating side is working well.
Any thoughts on the problem and how to recitify please ?
there is a diapragm in the divertor valve which is probably worn or stretched, needs to be replaced.
On that model its a knuckle scraping job to remove/repair.
Furthermore the large nut can be very difficult to remove now they are 16 years old.
Tony
Thanks for the informative replies.
Is changing the diverter valve something that I can do ? I know, you have no idea of my capabilities but I am good with plumbing having installed the complete central heating system some 11 years ago (only the water side as the gas side was done by a Corgi guy)
Thanks again
In theory you could do it yourself.
But if I find it a difficult job even when I have a selection of tools and experience of the problems, then I would suggest that you think twice about doing it.
Tony
