I wonder if anyone can help.
I have a Ravenheat CSI85T condensing combi boiler, fitted almost two years ago.
My problem is this. I turn the hot tap on and (yes, I timed this, sad, I know) 68 seconds later, I'm starting to get sort of warm water through. It takes maybe another 20 seconds before it's what I'd class as hot.
However..................
If the central heating is on and I turn a tap on, I get almost instant scalding water and it takes 43 seconds before it cools down enough to actually be able to put your hand under it.
I don't know if this is normal or not. I would have thought that this shouldn't happen because surely that must be some kind of safety issue - if a child or elderly person turned a tap on and got scalded. I've had a few sore scalds myself from it.
When the gas man came out to service it, I mentioned this to him and his explanation went along the lines of......
When the central heating is on, there is some water from the central heating remaining inside the boiler. When I turn a tap on, this water from the central heating is diverted into the tap and has to be run off before the water will reach the temperature that is set with the thermostat.
Is he just fobbing me off with some rubbish?
My poor hands can't take much more of the burning water because no matter how hard I try, I automatically put my hand under the tap when I turn it on.
I'd appreciate some advice because I don't want to go back and say there's a problem and look like a right idiot!
Also, one of my radiators seems not to be as hot as the others - the room that this radiator is in always feels cold. Using what I'd class as logical thinking I'd say it was the second last radiator in the loop, but what is logical to me might not have been to the cowboy that fitted the heating system!! I don't think it's an airlock because there are no hot and cold patches, the entire radiator just isn't as hot as the rest.
All advice greatfully received.
Many thanks,
Alison
Many thanks,
Alison
