Hi, I hope you can help please with some advice. I rent out a 3 bedroom house out with a Ravenheat combi boiler (approx 10 years old). The heat exchanger has clogged up for a second time in 2 years and water fluctuated between hot and cold water. It has a fernox magnet filter and an in line descaler. I have a British Gas contract on it and the engineer who is fitting a new heat exchanger on monday has said the heat exchanger is clogged due to the crap in the rads. The rads were flushed through 2 years ago, and I took them all off yesterday and flushed them each through with a hosepipe and there was a little of black water from each one, but minimal. Is there anything else that would cause the heat exhanger to keep clogging up?
This boiler has had about seven callouts in the last 18mth as parts keep failing, therefore I am looking to change the boiler for a system boiler, which would enable the tenant to still have hot water if the boiler fails. I am looking to install a Worcester Bosch, with a megaflow or similar tank in the loft (all boarded out and dry/clean) as I have no other room in the house. Would this work? any suggestions on reliable make of tank would be appreciated and is Worcester Bosch a decent reliable boiler?
Thanks in advance
Thanks in advance
