hI I have a Ravenheat condensing fanned combi boiler CCSI 85. Last year when the hot water was turned on the boiler fired up for a minute then stopped and fired up again, so the water was coming hot - cold - hot.
I lowered the hot water control a bit and hey presto I haven't had any problems since then until now! Now the heating system is acting up, the pressure is at 1.5 bar. The boiler will fire up for about one minute and shuts off with the fan, the pump still runs, then after about 30 seconds the boiler fires up and so the cycle continues. I moved the heating control and hot water control in the hope of an easy fix with no luck of course. Was hoping someone could tell me if this is an easy fix or will it require a Corgi lad to come in?
