Can anyone help My boiler has packed up and I cant fix it I have replaced the DHW & CH thermistors and now the fan works again but the boiler will still not fire unless you blow on the red tube that goes from the flue to the air pressure switch if you blow and pich the tube when it fires it will keep running but as soon as you let go of the tube it cuts out again. I put a brand new Ravenheat air pressure switch on today and it has made no difference, I have also lubricated the fan shaft and I runs nice and freely. What next as I have run out of ideas THANKS in advance chaps and chapeses.
