Replaced pipes and radiator in the lounge over the weekend. For this I had to drain the CH. After job completion, refilled the system, and fired up. Gurgled a lot in the boiler when the heating got going. Pipes got nice and hot, so no problems I thought, until I tested the DHW. Turning the tap on whirred the boiler into life, and after a longer than normal time, the water became hot. Then it went cold again. The boiler had it's orange light on (picture of a spanner by it), but still operational sounding noises coming from it. I can reset the system by cycling the main power, but the problem does re-occur.
My only other bolier experience has been with an Ariston, and that was fine to drain/refill the CH as required. Have I done anything wrong on this occasion? All the radiators were bled, and I have around 1.1bar pressure.
Cheers
Alex
Cheers
Alex
