Having gone through all ravenheat forums i do not seem to have found a proper answer to this problem.
Ravenheat csi85t will not fire up. after much diagnosis and cost of new gas valve (ravenheat tech advised) and air pressure switch it seem problem is air pressure switch is not reacting to change in air pressure flue pipe is drawing in air but switch not activating . if i blow across venturi i can get boiler to ignite but then goes off after a few seconds it seems that maybe chamber has an air leak as if i then seal pipe boiler stays lit until i can only think temp sensor kicks in will then not relight as it has to see open circuit on aps until fan starts then goes closed cct to active ignition.
sorry if this has been answered but i cannot seem to find conclusive answer.
derek
derek
