ravenheat fanned combi rsf 82e g.C. No 47 581 18
14 Mar 2010
West Midlands
Hi all
I am working on a ravenheat
g.C. No 47 581 18
And my customer has hot water problems .
I stripped the boiler back and found that the heat exchanger fins have melted somehow ?
It got a vertical flue and I'm thinking water must hv come down the flue and helped corrode the fins? I'm guessing , I found a cloth inside the boiler and customer said they had water dropping . The fan was difficult to remove as it was bonded on to the flue by dirt and rust.
The heat exchanger cost from 200 to 300 pounds
Before I change it, I want to be sure that it will cure the hot water problem . Central heating is fine.
If I restrict the water flow it starts kettling inside the heat exchange
Has engineer had the same issue ?
I want to help this customer as he's had issues in there life. Trying to keep there costs down.
Can anyone help?
If you are Gas Safe Registered then ask in the CC part of this site.
We are unable to give advice on gas/combustion issues here.
Tony
Sorted found it!!!
I didn't know this site was this good!!
Excellent
Thanks again Tony
