Hi
I have a slow leak from my diverter valve roughly in the middle between the diaphragm and the 3 way valve section.
The leak is from what looks like a small tube which connects the diaphragm housing to the 3 way valve, there are holes around its radius where it seems to be emitting drops..
At the moment its 1 drop every 5-10 minutes, so would have to wait to tell if boiler is loosing pressure...
I have spoken to Ravenheat who advised me to raplace the whole diverter valve assembly at £100. Part number 0002VAL06005/0.
Is there any other solution like repair and what part to get?
Hope I won't have to drain the CH system for repair/ replacement..
(If I need to, can I add inhibitor directly to the magnaclean container rather than buying the much more expensive inhibitor gun that feeds the chemicals through bleed valve?)
The boiler is a ravenheat HE85T. Entire CH (radiator by radiator) has been mains flushed and fitted with a magna clean and inhibitor added 2 weeks ago.
Can anyone please help?
