I am one of the unfortunate owners of a dreadful Ravenheat HE85T combi boiler. Its nearly 3 years old and has had since it installation:
1. New CH sensor 2 years ago
2. New DHW sensor 2 years ago
3. New divertor valve 1.5 years ago. The system was flushed a few times and then filled with cleaner and then inhibitor. I also installed a Magnaclean and clean it regularly.
4. New fan PCB (small credit card sized PCB) 6 months ago.
The boiler at the moment runs fine most of the time but I've these 2 intermittent issues:
1. The boiler is in DHW only mode at the moment but sometimes CH starts on its own after a DHW tap is turned OFF. this happens about once or twice a week at the moment.
When this fault occurs, sometimes the ON/OFF switch on CLOCK behaves in reverse logic as well. When I turn the CH to ON, it turns CH OFF and vice versa. The issue is resolved when I reset the power to boiler.
2. Sometimes I get this old issue of intermittent DHW in the shower. It happens mainly when CH is off. Does it need new CH/ DHW sensors again?
Thanks for your replies in advance..
